How to use the new PrusaSlicer in Repetier-Host?
zirak.c
(@zirak-c)
Hey Everyone,
I was able to use the previous Slic3r Prusa Edition as it was just a modified version of Slic3r, and was able to add the configuration to Repetier-Host.. is there a way to do this with the new Prusa Slicer?
Thanks!
Respondido : 30/05/2019 2:26 am
adam.l
(@adam-l)
RE: How to use the new PrusaSlicer in Repetier-Host?
Hi there,
I'm running Repetier-Server as well and I'm not sure what you're asking.
I am a bit a of a novice though so...
I have the MK3S set up in Repetier as a printer and not Slic3r. How were you adding Slic3r to Repetier-Server?
Respondido : 05/06/2019 9:47 am
Andreas
(@andreas)
the new silcer version has no effect on your reptier configuration. Just upload the gcode as before. Only the slicer is "unknown" in the print details overview. Maybe this will be updated soon.
If you need a guide to setup your prusa with Repetier Server, please check this link
https://andreas-reitberger.de/knowledgebase/prusa-i3-mk3-mit-repetier-server-pro/
Attachment removed
Download our 3D Print Cost Calculator Tool:
https://andreas-reitberger.de/en/3d-druckkosten-kalkulator/
Respondido : 08/06/2019 6:24 am
