how to to initial setup?
Yaka
 Yaka
(@yaka)
hi i got a pre-built mk3s+ some time ago with enclosure but only just managed to set it up today. i was going through the first power on and setup procedure and got the point it was doing the heat-up  but it was fluctuating between 5c to 7c and never got higher even after 15 minutes, i should have known my garage was too cold  and stupidly i pressed the X button. now every time lcd shows mintemp error.
 reading up on it i think if i heat up my garage  and possible warm up the enclosure up heat a heat gun i should be ok . but can the setup process be done again and if so how?
Napsal : 11/03/2023 10:33 pm
RE: how to to initial setup?
Posted by: @yaka
is it a factory reset you wish to initiate?
https://help.prusa3d.com/article/factory-reset-mk2s-mk2-5s-mk3s_2216
Napsal : 12/03/2023 1:10 am
1 lidem se líbí
Yaka
 Yaka
(@yaka)
thank you so much for the quick and speedy reply got the printer up working this morning
Napsal : 12/03/2023 10:20 pm
