How to set the range of layers to apply Variable Layer Height?
Hi, it looks like whenever this function is activated, it applies to all the layers. Is there any way to specify the range of layer heights within which this function is applied? For example, if the object has a height of 100mm and I want to apply variable layer height to layers from 10.2mm to 40.5mm, how do I do that?
Opublikowany : 10/10/2022 8:48 pm
