[Solved] how to replace broken extruder body
anricco
(@anricco)
Hello,
Thank you. Unfortunately the extruder body broke while printing a highly warping material, as in the picture, because the PINDA sensor kept hitting the object on the printing bed. Also using superglue has prove an ineffective solution for the broken part. Since this MK3S printer was bought as an already built printer, if possible it would be very useful a guide on how to disassably only the parts that are useful to replace the extruder body, since there seems to be only a guide on how to replace the hotend. Wish you a nice day.
Looking forward to hearing from you, thank you and best regards.
A.R.
Napsal : 18/09/2021 1:54 pm
Walleye
(@walleye)
Replacement Parts
You can order a replacement from Prusa. Look for the Spare Parts tab on the main Prusa page.
Napsal : 19/09/2021 3:19 am
anricco se líbí
anricco
(@anricco)
Posted by: @walleye
Hello,
Thank you for your answer. In fact the replacement was printed in black ABS before the definitive break down of the part. So the question would be about the procedure to replace the extruder body, that is, which parts have to be disassembled and which parts can be left in place in order to make the replacement. Maybe somewhere there is an appropriate guide with the steps. Wish you a nice day.
A.R.
Napsal : 19/09/2021 6:13 am
Dan Rogers
(@dan-rogers)
Look at the assembly manual, and go in reverse
There is quite an involved process, and the same manual that you would use to assemble the printer (if you bought the kit) is your best friend for figuring out how to reverse assemble the extruder.  In general broad strokes, take off the four screws holding the extruder chassis to the X rails - that will let you separate the extruder mechanism from the printer.  Follow the assembly instructions in reverse - you will need all of the tools that came with the printer (the different size and length allen wrenches).
The assembly manual is on line.  And you can probably purchase the paper copy from Prusa (the on-line version is more up to date).
Napsal : 19/09/2021 10:45 am
anricco se líbí
jsw
 jsw
(@jsw)
I have not had to use any of it yet, but as this post points out, I think one of the best 'preventive' measures that anyone can do with the I3 series is to print spares of the extruder parts, those most likely to get damaged during a Blob Of Doom Meltdown.
I did this shortly after getting the machine, black ABS, and have the pieces in the 'crash kit' in the event of an issue.
I do have a spare print fan shroud in there, but since I printed the spares I have switched to a remixed one, printed in PC Blend.
Napsal : 19/09/2021 9:11 pm
anricco se líbí
instructions
I would follow the directions in reverse:
https://help.prusa3d.com/en/guide/5-e-axis-assembly-textile-sleeve_71288
You will not have to do it all, but read all of the instructions forward and backward before attempting.
Napsal : 19/09/2021 9:56 pm
anricco se líbí
MichaelK
(@michaelk)
Check the upgrade instructios.
You could also follow the disassembly instructions in the upgrade section.
https://help.prusa3d.com/en/guide/2a-mk3-extruder-disassembly_182045
Napsal : 21/09/2021 3:27 am
anricco se líbí
anricco
(@anricco)
Hello,
Thank you for all your answers and kind explanations. Apparently the only way is to fully disassemble the printing head. On the bright side this will be an opportunity to learn the procedure. Hopefully it will be possible to do it without unplugging all the cables. Wish you a nice day.
A.R.
Napsal : 23/09/2021 11:39 am
Dreamcazman
(@dreamcazman)
RE: how to replace broken extruder body
Sorry to dig up an old post, the exact same thing happened to my printer today, must be a weak spot. Just wondering how you got on replacing the extruder body?
I managed to glue mine so I could print a replacement. Even though I built my printer as a kit, I'm not looking forward to pulling it apart again, sigh...
Napsal : 14/10/2024 1:53 am
in 2016 a roll of filament fell off the grotty filament spool holder of My Mk1 printer. it collided with the Y Motor and snapped the printed bracket,
Like you, I Glued it back together and the first thing I Did was to print two stronger replacement parts, one for the damaged machine and one for a second machine that was awaiting assembly.
when I assembled the second machine, I fitted the alternative part and that is still working well,
Like you,
I didn't fancy disassembling the repaired machine at that time, so I Kept the part in a drawer under the printer until such time as the repaired part failed totally, or I was doing  a significant upgrade...     the repaired part has neve been visited by another roll of filament, it has never broken and the spare part is still in the drawer...
that printer is now  a Mk2 printer with MMU1... however neither the Mk2 upgrade, nor the MMU1 upgrade required the main frame to be disassembled...
if you have a mk3S, you may consider the Mk3S+ parts for replacement, or you may consider a mk3.9 upgrade in preference to simply rebuilding what you already have.
Napsal : 14/10/2024 9:14 am
Dreamcazman
(@dreamcazman)
Posted by: @joantabb
Thanks for the suggestions. I did the MK3 - MK3S upgrade a few years ago. I don't do a lot of printing so I'll just swap out the broken piece. An extra costly upgrade just isn't worth it for me at the moment.
Napsal : 14/10/2024 9:41 am
and...   that's why I Still have a Mk2 MMU1 in my workshop!    🙂
Good luck.
Regards Joan
Napsal : 14/10/2024 11:05 am
