How to repair scratch in heat bed
JPMakesStuff
(@jpmakesstuff-2)
Utenti
I don't know how it happened, but I have a small scratch in the heat bed, directly over one of the wire traces such that I can see the copper.  Might not be an issue since there are no other scratches of exposed copper, thereby causing a short.
But is there a way to fix it? some kind of heat resistant goo that can fill the small scratch and not cause a bump?
Postato : 05/01/2022 5:43 pm
RE: How to repair scratch in heat bed
It shouldn't cause an issue as the pei on the print sheets is non conductive but you can fill in the scratch with varnish or lacquer.  Nail varnish works but better ask before borrowing if you don't any of your own  🤣
Postato : 05/01/2022 8:43 pm
