How to go back from MMU2S to just MK3S
trixi.s
(@trixi-s)
Hello,
I have problems making my mmu2s work properly. Since I have some important work coming up, I would like to go back to the very reliable MK3S printer. Is there a discribton for this procedure? Can I just takte off the MMU2S and use the extruder as it is, or do I have to take out the senosor the was put in for the MMU2S? I guess, I have to flashe the printer with the MK3S firmware afterwards, right?
Opublikowany : 07/08/2019 2:10 pm
Dave Avery
(@dave-avery)
RE: How to go back from MMU2S to just MK3S
just unplug the cable between the MMU and EINSY - no firmware change. the same firmware supports both configurations if the firmware hears from the MMU it enables the MMU options
Opublikowany : 07/08/2019 3:57 pm
1 ludzie polubili
trixi.s
(@trixi-s)
Ahh, GREAT!! Thank you , so I can switch rather easily between the two. It would be a shame to give up the MMU completely, I just don`T have the time to optimize it right now.
Thanks !
Opublikowany : 07/08/2019 4:05 pm
