How to change Z height in firmware?
Antony
(@antony)
Hi there
Noob here, first post
I have replaced the trapezoidal nut on my MK3 using this adapter https://www.thingiverse.com/thing:2390436 , this changed the maximum Z height. I've try to use Z calibration and XYZ calibration to fix it but apparently it doesn't work.
A quick google search told me I need to adjust the Z height in the firmware, but I don't know where is the parameter. https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.5.2
Could anyone help me find where that parameter is located in the firmware using Arduino IDE? And are there any other parameters I need to change as well?
Cheers
Edit: Another question, will I still be able to use Z calibration after changing the firmware?
Posted : 22/02/2019 11:20 am
wieman01
(@wieman01)
Re: How to change Z height in firmware?
First layer calibration should work for you, you find it under Settings I believe.
Also when you print, you can alway Live Adjust the Z height which is then also saved for future printing.
Check it out, it should be relatively straightforward.
3D Druck für Einsteiger leicht gemacht: www.3d-druck-lernen.de
Posted : 22/02/2019 11:35 am
Antony
(@antony)
Re: First layer calibration should work for you, you find it under Settings I believe.
Thanks for the replay, although running a first layer calibration will the level the bed, the printer still display a error message "Calibration failed, check the axis and run again" when I try to run Z or XYZ calibration. Do you have any ways to get around this problem?
Posted : 22/02/2019 11:58 am
richard.l
(@richard-l)
Member Moderator
I think the real question that should be asked is why did you use this adapter?
Posted : 22/02/2019 4:53 pm
Martin Wolfe
(@martin-wolfe)
It would have been far better to design modified X-Ends to take the new trapezoidal nuts directly. Such a design is in my to do queue as I have a pair of brass replacements sitting on my desk waiting to be fitted as my plastic ones show slight signs of wear.
Regards,
Martin
Martin Wolfe
Posted : 22/02/2019 5:57 pm
Antony
(@antony)
I'm using it because the holes on the brass trapezoidal nuts are closer to the center compare to the stock plastic nut.
Posted : 22/02/2019 7:18 pm
andrea.f9
(@andrea-f9)
see here 😉
Posted : 30/03/2019 1:51 pm
