How to Adjust Crash Sensitivity
gmbarton
(@gmbarton)
I'm getting a lot of Y crashes for no apparent reason. The belt status is good (264).
I've heard that the crash sensitivity can be reduced with the line
M916 Y5 ; reduce y crash sensitivity, default 3 max 63, higher numbers less sensitive
But then I read that TMC2130_SERVICE_CODES_M910_M918 must be enabled for the M916 code to work. How do I do that? Does that change need to be made to the firmware? If so, how?
Any help will be appreciated.
Opublikowany : 11/05/2021 6:44 pm
RE: How to Adjust Crash Sensitivity
Posted by: @gmbarton
To enable these M codes change the following:
Configuration_prusa.h
from
//#define TMC2130_SERVICE_CODES_M910_M918
to
#define TMC2130_SERVICE_CODES_M910_M918 // kgolger - activate M916 crash sensitivity - https://help.prusa3d.com/en/article/prusa-specific-g-codes_112173
Then recompile (Linux or Windows - is described here) and flash.
good luck 👍
Opublikowany : 11/05/2021 6:52 pm
gmbarton
(@gmbarton)
I found the file  1_75mm_MK3S-EINSy10a-E3Dv6full.h
I then found this line inside the file
<td id="LC283" class="blob-code blob-code-inner js-file-line"><span class="pl-c"><span class="pl-c">//</span>#define TMC2130_SERVICE_CODES_M910_M918</span></td>
Do I change it to the following?
<td id="LC283" class="blob-code blob-code-inner js-file-line"><span class="pl-c"><span class="pl-c"></span>#define TMC2130_SERVICE_CODES_M910_M918</span></td>
Or am I looking in the wrong file?
Opublikowany : 11/05/2021 7:41 pm
Dan Rogers
(@dan-rogers)
Just a thought.  Do you have any pictures of like a calibration cube?  You mentioned belt tension #'s - those you can safely ignore, they are not used to adjust the belts.  Download the pattern for the belt tension tool from the print library, and print it using Prusament PETG (only Prusament Petg or the dials will be off).  That will help you measure your belt tension.
Lots of things can cause a Y crash issue - #1 is blobbed up head runs into print.  A few more are
- turn off the printer, and slowly move the bed from front to back.  Go slowly because the motor will back feed electrical spikes into the circuitry. Or disconnect the belt and do the go slowly back and forth.  The movement should be smooth - and if the motor is disconnected, nothing should impede the Y track movement.
I have seen things like misplaced Zip ties rubbing the bed, unparallel Y rods (not seated), over-tightened Y carriage bearing holders.
That will help you isolate tension/impeding movement issues from belt tension.  Fix whatever is causing the drag.
One possibility that is also common is your belt is too tight.  Print out that tension gauge and center it in the sweet spot.
Opublikowany : 11/05/2021 8:07 pm
A crash is a crash - and they do not happen for no reason. Masking them is easy enough: just run the printer in stealth mode.
Opublikowany : 11/05/2021 8:13 pm
@gmbarton
Copy the file "1_75mm_MK3S-EINSy10a-E3Dv6full.h" (suitable for your einsyboard) from the sub directory "variants" to the enclosing directory "firmware" and rename it to "Configuration_prusa.h".
Maybe this video could help you:
Opublikowany : 11/05/2021 8:35 pm
I had a lot of crashes on one printer.  I turn off the detection.  It went away after I reinstalled the firmware.  It now works with the crash detection turned on.
Opublikowany : 12/05/2021 2:26 am
gmbarton
(@gmbarton)
@karl-herbert
Thanks for the video! This clearly explains many things I was missing in recompiling the code. Now I get this error in Arduino when I check firmware.ino in Arduino
Because I have activated TMC2130_SERVICE_CODES_M910_M918, what do I need to include as arguments for tmc2130_init() ?
Opublikowany : 12/05/2021 3:30 pm
@gmbarton
Which editor did you use to make the changes? Originally this should look like this (3.8.1):
### M915 - Set TMC2130 silent mode <a href="https://reprap.org/wiki/G-code#M915:_Set_TMC2130_silent_mode">M915: Set TMC2130 silent mode</a>
Not active in default, only if `TMC2130_SERVICE_CODES_M910_M918` is defined in source code.
case 915:
   tmc2130_mode = TMC2130_MODE_SILENT;
   update_mode_profile();
   tmc2130_init();
break;
Which firmware version exactly do you need (MK3 3.10.0 or MK3S 3.10.0....or an older version)?
I could provide you with the changes.
Opublikowany : 12/05/2021 4:55 pm
gmbarton
(@gmbarton)
@karl-herbert
I used Visual Studio Code on Windows 10. The firmware I'm trying to modify is MK3S 3.10.0.
Thanks.
Opublikowany : 12/05/2021 5:06 pm
@gmbarton
sent you a pm!
Opublikowany : 12/05/2021 7:09 pm
gmbarton
(@gmbarton)
Success!
With the modified firmware, I set the Y sensitivity to 7 and successfully ran an ABS print that was 40mm tall. In 3 previous attempts, it would keep "crash detecting" around 1mm height and I was unable to get it to progress any further.
Thanks @karl-herbert!
Opublikowany : 13/05/2021 5:47 am
@gmbarton
glad it helped temporarily. I would still check the mechanics of the axles for irregularities.
Opublikowany : 13/05/2021 10:30 am
who1sjoe
(@who1sjoe)
@karl-herbert
I have a similar problem. Is it possible that you can also help me with the definition of TMC2130_SERVICE_CODES_M910_M918?
Thanks in advance
Opublikowany : 10/09/2021 5:26 pm
@who1sjoe
Which FW version and which printer (MK3 or MK3S)?
wbr,
Karl
Opublikowany : 11/09/2021 11:03 am
who1sjoe
(@who1sjoe)
@karl-herbert
I use the FW 3.10.1 and have a MK3S+
Opublikowany : 11/09/2021 11:08 am
