How do I modify the bed leveling calibration function to use a different extruder temp?
Just upgraded MK3S+ to MK3.5.
Gcode generated by Prusaslicer Version 2.7.4 for Generic PLA
M104 S215 ; set extruder temp
M140 S60 ; set bed temp
M190 S60 ; wait for bed temp
M109 S215 ; wait for extruder temp
When executing the PLA print, prior to starting the 49 point bed leveling calibration, print execution pauses until the extruder temp reaches 215C as expected. Then the extruder temp drops to 170C and then the bed leveling calibration is executed. Once the calibration is finished, the extruder temp rises to the 215C temp as defined by the print gcode, and actual printing starts.
How do I modify the bed leveling calibration function to use a different extruder temp so I can reduce the pauses between temp changes?
RE: How do I modify the bed leveling calibration function to use a different extruder temp?
This is part of the start code I use: (downloaded it and changed some parts myself), Maybe helpfull.
You will see a series of M190 S?? settings. I use this to avoid the MINTEMP error when it is cold.
It divides the warmup to 30 degrees in small steps.
The nozzle is placed close to the heatbed, so the PINDA warms up before leveling.
Then it does AUTOHOME and waits for the temps of bed and nozzle.
Lays a nice fat layer outside the printarea, small wipe and starts printing.
; Set initial warmup temps
M117 Nozzle preheat
M104 S160 ; set extruder no-ooze temp
M190 S13
M190 S15
M190 S17
M190 S19
M190 S21
M190 S23
M190 S25
M190 S27
M190 S29
M140 S{if printer_model=~/.*MK25S.*/}[first_layer_bed_temperature]{else}{max(first_layer_bed_temperature[0],65)}{endif} ; set bed PINDA warmup temp
; Nozzle warmup before home to avoid driving hardened ooze into PEI surface
M109 S160 ; wait for extruder no-ooze warmup temp before mesh bed leveling, cool hot PINDA
; Home
M300 S40 P10 ; chirp
M117 Homing
; Present bed for final cleaning
G0 Z3; Raise nozzle before move
G0 X125 Y180 F10200; Move nozzle to PINDA warming position
G0 Z0.15 F10200; Lower nozzle to PINDA warming position
; Wait for PINDA warmup
M117 PINDA warmup
M117 Mk25S detected, no warmup required
{else}
M117 Mk3 Waiting for PINDA warmup
M860 S35 ; wait for PINDA temp to stabilize
{endif}
M140 S[first_layer_bed_temperature] ; set bed final temp
M104 S[first_layer_temperature] ; set extruder final temp
; Mesh bed leveling
M117 Mesh bed leveling
G80 ; mesh bed leveling
M117 Saving results
G81 ; save mesh leveling results
; Final warmup routine
M117 Final warmup
G0 Z5; Raise nozzle to avoid denting bed while nozzle heats
M109 S[first_layer_temperature] ; wait for extruder final temp
M190 S[first_layer_bed_temperature] ; wait for bed final temp
; Prime line routine
M117 Printing prime line
G0 Z0.15 ; Restore nozzle position - (thanks tim.m30)
M900 K0; Disable Linear Advance for prime line
G92 E0.0 ; reset extrusion distance
G1 Y-2.5 F1000.0 ; go outside print area
G1 E2 F1000 ; de-retract and push ooze
G1 X20.0 E6 F1000.0 ; fat 20mm intro line @ 0.30
G1 X60.0 E3.2 F1000.0 ; thin +40mm intro line @ 0.08
G1 X100.0 E6 F1000.0 ; fat +40mm intro line @ 0.15
G1 E-0.8 F3000; retract to avoid stringing
G1 X99.5 E0 F1000.0 ; -0.5mm wipe action to avoid string
G1 X110.0 E0 F1000.0 ; +10mm intro line @ 0.00
G1 E0.6 F1500; de-retract
; Final print adjustments
M117 Preparing to print
; Adjust extrusion rate if desired
; M221 S{if layer_height >= 0.32}90{else}100{endif} ; compensate for thick layer heights
M117 Print in progress
Eef the trouble is if the OP has a pinda without the thermistor, ie one of the 'new' super pinda's then the M860 from your start gcode should not be used. Anyone with the older pinda can use it (as I do myself).
To the OP, as the desired no ooze extruder temp might be different for different filaments you can use something structured like the following
M104 S{first_layer_temperature[0]-50} ; set extruder no ooze temp to filament -50
or if you want to wait for the temp to stabilise the following
M109 S{first_layer_temperature[0]-50} ; set extruder no ooze temp to filament -50, wait for extruder no-ooze warmup temp before mesh bed leveling, cool hot PINDA
Of course you can change the -50 offset to whatever you want.
M104 S{first_layer_temperature[0]-50} ; set extruder no ooze temp to filament -50 or if you want to wait for the temp to stabilise the following M109 S{first_layer_temperature[0]-50} ; set extruder no ooze temp to filament -50, wait for extruder no-ooze warmup temp before mesh bed leveling, cool hot PINDAOf course you can change the -50 offset to whatever you want.
Thanks for this suggestion. I will integrate this in my startup-script.
Could you post your startup script. So we can read if there is a command somewhere what forces the printer to wait for the 170.
