How do i change this setting?
jake.m3
(@jake-m3)
Opublikowany : 20/07/2019 4:10 pm
JBinFL
(@jbinfl)
RE: How do i change this setting?
If that is a system setting, e.g. one of the system preset profiles that are automatically installed, you cannot change it without renaming the profile as something else first.
For example, 0.20MM Quality system preset, change something that is not greyed out and hit save and rename it like 0.20MM Quality 072019.  Then put back what ever you changed and that should not longer be greyed out.
Or you can enable supports on the plater screen and that will un grey it, change the setting and save the name as something else to save the preset.
Strange women, laying in ponds, distributing swords, is hardly a basis for a system of governance!
Opublikowany : 20/07/2019 4:30 pm
You have to have support enabled to edit the value.
Opublikowany : 20/07/2019 8:03 pm
And - a hidden fact is you really really do not want to change the setting.  Plicer uses auto layer when building support, and if you change the extrude width you can mess up the extrusion height calculations and leave yourself with unstable support towers.
Opublikowany : 20/07/2019 8:16 pm
