[Solved] How can I tell which version of a MK3 I have
idaho bill
(@idaho-bill)
How can I tell which version of a MK3 I have.  When I ordered the printer I thought I ordered a MK3S+ kit.  I have to order a hot end and the info screen shows the printer as an I3 MK3S.    The parts are different for each version.  I could use a little help so that I order the correct Assembled Hot End.
Napsal : 22/10/2022 12:21 pm
idaho bill
(@idaho-bill)
RE: How can I tell which version of a MK3 I have
Napsal : 22/10/2022 12:27 pm
does your filament tension trapdoor have 2 tension screws?  If so, Mk3
Does your Filament trapdoor have 1 tension screw and a Black Filament Sensor PCB and 4 wirePinda, If So Probably Mk3S
Does your Filament Trapdoor have a single tension screw, is your filament sensor PCB Red and does your Pinda have three wires... Mk3S+
Napsal : 24/10/2022 10:30 pm
Ty a se líbí
