How can I tell which version of a MK3 I have
How can I tell which version of a MK3 I have. When I ordered the printer I thought I ordered a MK3S+ kit. I have to order a hot end and the info screen shows the printer as an I3 MK3S. The parts are different for each version. I could use a little help so that I order the correct Assembled Hot End.
RE: How can I tell which version of a MK3 I have
does your filament tension trapdoor have 2 tension screws? If so, Mk3
Does your Filament trapdoor have 1 tension screw and a Black Filament Sensor PCB and 4 wirePinda, If So Probably Mk3S
Does your Filament Trapdoor have a single tension screw, is your filament sensor PCB Red and does your Pinda have three wires... Mk3S+
