Hotend won't heat
I had a print that created a huge ball around the end of the printer, so I had to replace the hot-end because it broke the wire. I hooked up a new one and it heated up good the first time but now it won't heat anymore. The connection is good and just stays at room temp. I just replaced the fuses but nothing has worked so far. Any ideas?
Respondido : 01/07/2020 9:37 pm
