[Gelöst] Hotend temperature unstable
Jiheffe
(@jiheffe)
After a couple of small printys this morning, I switched off my i3 Mk3S and turned it 180° in order to mount this enclosure for a Rastberry Pi. I placed it back, removed the PETG and loaded PLA, and switched the textured plate for a smooth. I also took the opportunity to place a LED ribbon on the frame.
Put the printer back in its normal position, and loadeda small calibration *.gcode to check the life-Z. Now, the hotend temperature will not stabilize ar 215° C but goes in cycles between abour 185° and 230°... See graph below:
I shut down and restarted the printer, restarted Octoprint, to no avail. I disconnected the Pi with Octoprint just in case, but no change.
Could it be that by turning the printer around, the thermistor connector got loose on the Einsy board?
Veröffentlicht : 06/06/2020 4:07 pm
RE: Hotend temperature unstable
Are you taking power from the printer to power the led strip or ?  You might also want to run the pid process for the extruder heater.
Veröffentlicht : 06/06/2020 4:20 pm
Jiheffe
(@jiheffe)
@neophyl
No, both the Pi and the strips are on their own power supplies. Will do the PID.
I looked into the Einsy for any loose connextion but all seemed OK.
Veröffentlicht : 06/06/2020 4:35 pm
Jiheffe
(@jiheffe)
Update:
Started a PID calibration, it stopped immediately after 1 second. Started again, after 10-20 seonds I a message "M112 called. Emergency stop", Octoprint reported a "HOTEND THERMAL RUNAWAY"...
I have a spare thermistor. Guess this would be the time get it out?
Veröffentlicht : 06/06/2020 4:45 pm
@jiheffe
With such large deviations, you are almost certain to have a loose contact on the thermistor or on the heating cartridge. This is noticeable when the printer is in motion. A wire may also be squeezed. I would check and meassure these wires.
Veröffentlicht : 06/06/2020 7:06 pm
Jiheffe
(@jiheffe)
Update 2:
1/ Wife called for dinner 😎
2/ Back to the printer, started a preheat at PLA temperature -> Resulted once again in thermal runaway...
3/ Removed and reinserted the hotend thermistor (ditched the blue E3D sock)
4/ Successfully did a test print of a 50x50x0.2 mm calibration square
5/ Ran PID calibration -> success
6/ Now happily printing again
Could it be the thermistor had a problem? Note I didn't replace it. Just removed from the heatblock and reinserted it.
Veröffentlicht : 06/06/2020 7:08 pm
@jiheffe
It's good to see the printer up and running again. Possibly there was a short circuit. Loose contacts, and short circuits are a common cause of such problems. Another possibility would be a too high fan speed, which then cools the nozzle down too much (in this case you could use a silicone sock or reduce the fanspeed). If the pidtuning is not optimal, the temperature deviation is only a few degrees C.
I would still do the pidtuning e.g. at 240/90 degrees (PETG) with running nozzlefan (see Slicersettings for the fanspeed): https://mattshub.com/blog/2017/04/26/pid-tuning
Veröffentlicht : 06/06/2020 7:48 pm
Jiheffe
(@jiheffe)
Posted by: @karl-herbert
Thnx! Will do.
JF
Veröffentlicht : 06/06/2020 8:01 pm
