hotend temperature is not reached
Hello MK3 enthusiasts,
after I removed a blockage in the hotend and everything is reassembled the hotend reaches only a temperature of about 150 degrees.
what can be the reason?
the normal fan runs all the time. is that normal?
Thanks Martin
Napsal : 12/08/2018 11:28 am
Topic starter
answered:
Re: hotend temperature is not reached
Solution:
The heat sink of the hot end was screwed too far onto the hot end so that too much heat was extracted from the heating element.
Napsal : 12/08/2018 12:04 pm
Hi Martin.
Was it bridging the heartbreak?
Regards Joan
Napsal : 12/08/2018 1:15 pm
