Hotend leaking after Prusa Vid on how to change Nozzle
TabalugaLH
(@tabalugalh)
I saw, how easy it is in the vid of Mr. Prusa on Youtube and did exactly the same.
But of course it leaked... Just a bid so the first print went well and I could not see anything.
But the second failed badly and the whole mess of PLA build up...
I would have never changed that nozzle, if the vid did not make it look easy...
Now I am fucked...
So how do it get it tight - I think when I do the last step and try to tighten the heater block - it moves. so it would need to be diagonal in order to be tight...
And how do I get rid off the mess of PLA without spending hours. How do I get the fucking thing in the right orientation so that I can tighten the heaterblock in the end.
And why is there no vid with the clean up after a failed nozzle change and only showing the fancy non reality instead of the mess that happens
Napsal : 01/09/2025 12:10 am
TabalugaLH
(@tabalugalh)
RE: Hotend leaking after Prusa Vid on how to change Nozzle
Awesome Help!!!
I will remember, when I buy the next printer.
Napsal : 02/09/2025 12:37 pm
Pay particular attention to the diagrams at the bottom of this page:
https://help.prusa3d.com/en/article/changing-or-replacing-the-nozzle-mk2-5s-mk3s-mk3s_2069
Napsal : 02/09/2025 2:17 pm
