        Hotend fuse max rating
I can't seem to find what is the maximum current rating for hotend heater driver?
Can I replace 5A fuse for hotend with slightly higher rating (up to 7A)?
Thank you in advance
                            Opublikowany : 20/02/2019 9:08 am
                    Re: Hotend fuse max rating
24v x 5a = 120w ... why do you need more power than that?
                            Opublikowany : 23/02/2019 11:55 pm
ps: Q1, the hot end driver FET is rated 100 amps ... lol.
Schematics here: you should be able to find part numbers of things like connectors by searching.
 https://github.com/ultimachine/Einsy-Rambo/blob/1.1a/board/Project%20Outputs/Schematic%20Prints_Einsy%20Rambo_1.1a.PDF
                            Opublikowany : 26/02/2019 4:55 am
