Hotend does not receive voltage after printing for some time
Pagina 1 / 2
Thomas Wang
(@thomas-wang)
I recently upgraded my hotend to a revo 6 because my old one was starting to get impossible to clean. After installing I ran a print and came back to it being half finished because of thermal runaway in the hotend. Doing some probing I noticed that sometimes that the hotend doesnt receive any voltage from the board and the LED attached to it on the board doesn't light up either. My theory is that the mosfet or whatever controls the voltage is overheating so that when I turn the printer off and go to check the cables it has enough time to cool down to heat the nozzle for a short amount of time. This graph is from an initial print after leaving the printer off for the night. Is there anything else that would do something similar or do I now just need to point a fan at my control box.
Postato : 05/01/2023 8:44 pm
Hello
(@hello)
RE: Hotend does not receive voltage after printing for some time
If you have the old one you could always try that and if it still does with the old one if printer is under warranty contact support though live chat as could be something on the board that's faluty
Postato : 05/01/2023 9:06 pm
Thomas Wang
(@thomas-wang)
The old one doesnt work because the thermistor is damaged and the printer is about 4-5 years old.
Postato : 05/01/2023 9:14 pm
Hello
(@hello)
Oh ok I don't see how anything would over heat heaps of people make thses kind of mods
Postato : 05/01/2023 9:15 pm
Thomas Wang
(@thomas-wang)
I didnt think it would be a problem either. But nothing else explains why it prints longer when left off for awhile, and can heat the hotend but drop voltage.
Postato : 05/01/2023 9:18 pm
Hello
(@hello)
maybe try put a fan on it but if it keeps doing it then could be dangerous so if fan doesn't work i would just replace the board rather then risk it. any chance you can post photo of board so i can have a good look at it and maybe downgrade firmware and do factory reset
Postato : 06/01/2023 6:04 am
Thomas Wang
(@thomas-wang)
I'll try and reset firmware first as I dont have fan laying around to use and my wiring isnt tidy enough to see the board so I'd need to take it out.
Postato : 06/01/2023 6:22 am
Thomas Wang
(@thomas-wang)
IMG_0333
message (2)
So some things have happened. I believe the issue with the hot end is gone but updating and resetting the printer has caused other issues. I started to get issues with starting prints with octoprint. Starting prints initially causes "Printer sent 'start' while printing. External reset? Aborting job since printer lost state." Then I tried reflashing the same firmware only for the reflash to fail and now it looks like my printer is having a seizure.
Postato : 06/01/2023 9:51 am
Hello
(@hello)
What firmware are you on I believe there is an issue with the newest firmware where some printers do that and don't boot try down grade firmware
Postato : 06/01/2023 7:13 pm
Hello
(@hello)
If that all fails press the button on the top of Rambo next to the USB port to update it
Postato : 06/01/2023 7:18 pm
Thomas Wang
(@thomas-wang)
Im currently using the latest version which is 3.11.0 ill try downgrading
Postato : 06/01/2023 11:57 pm
Thomas Wang
(@thomas-wang)
downgrading the firmware fixed the issue however octoprint is still not playing nicely with the printer. When I start a print for the first time it says that the printer was reset when it wasnt and then printing again allows it to print but then it randomly shuts down mid print.
Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Send: N1410 M105*19
Recv: \x00start
WARNThe received line contains at least one null byte character at position 0, this hints at some data corruption going on
Changing monitoring state from "Printing" to "Cancelling"
Send: N0 M110 N0*125
Recv: echo: 3.10.1-4697
Recv: echo: Last Updated: Dec 16 2021 12:32:39 | Author: (none, default config)
Recv: Compiled: Dec 16 2021
Recv: echo: Free Memory: 2059  PlannerBufferBytes: 1760
Recv: echo:Hardcoded Default Settings Loaded
Recv: adc_init
Recv: Extruder fan type: NOCTUA
Recv: CrashDetect ENABLED!
Recv: FSensor ENABLED (sensor board revision:unknown state)
Recv: echo:SD init fail
Recv: LCD status changed
Postato : 07/01/2023 12:13 am
Hello
(@hello)
Strange maybe the board is faluty
Postato : 07/01/2023 12:20 am
Hello
(@hello)
What do you think
Postato : 07/01/2023 12:21 am
JimB
 JimB
(@jimb)
Have you tried a different USB cable?  What kind of system (hardware/OS) is running octoprint?
Postato : 07/01/2023 2:21 pm
Thomas Wang
(@thomas-wang)
I tried running the printer with just an SD card and no raspberry pi plugged in and it still did the same thing. not sure what it is.
Postato : 07/01/2023 6:58 pm
Hello
(@hello)
I'm wondering wether it something to do with power panic try unplug power panic cable
Postato : 07/01/2023 7:14 pm
Thomas Wang
(@thomas-wang)
I unplugged the power panic and it still didnt work. Ive also noticed that something weird is happening to my screenIMG_0339
Postato : 07/01/2023 8:56 pm
Hello
(@hello)
Before this starting happening did you touch the einsy
Postato : 07/01/2023 8:58 pm
Hello
(@hello)
If you touch einsy or lcd without discharging yourself you can send electric static to the lcd witch can travel to the board or static electricity streight onto the board Wich can mess some things up some of us touch top screw of the PSU Wich is grounded.thats why they always say hold board by sides
Postato : 07/01/2023 9:01 pm
Pagina 1 / 2
