Hot End Thermal Runaway
I'm having an issue with hot end thermal runaway while trying to print a part out of nylon. The print fails in the exact same spot every time. I did notice that when is failed that the layer cooling fan was running at full blast. I'm almost 100% positive that I have the fan disabled in Slicer. So now my question is does the fan come on when there is a thermal runaway at the hot end as a safety precaution? Or do I have a setting in Slicer wrong that's causing the cooling fan to come on?
Opublikowany : 09/10/2019 9:18 pm
