Hot end not reaching temp
JamesPet
(@jamespet)
I recently started a 24hr print.  About 10 hours into the print I got a Thermal runaway error.  Since then the I can not get the printer to get above 190 in the readings.  I did smell a little burning on the first attempt to print after the failure, but nothing since.  The I have had the printer for about a month now and no printing issues until this point.  I would appreciate any suggestions.
Prusa MK3S+ Kit MMU2S
Napsal : 10/01/2023 1:53 pm
3DCoded
(@3dcoded)
RE: Hot end not reaching temp
I had a similar problem a few months when using a 30W heater cartridge instead of the stock 40W. Did you make any changes to the hotend from stock?
Napsal : 10/01/2023 3:30 pm
JamesPet
(@jamespet)
No changes.  completely stock system.
Napsal : 10/01/2023 3:45 pm
JamesPet
(@jamespet)
I was able to get it to load a new filament.  PLA  but after it reached temp it started to smoke and spit lava on the bed.  I think the thermistor has failed. I'll order a new one and update after.
Napsal : 10/01/2023 4:42 pm
