Hot end does not heat
gulprint
(@gulprint)
For my MK3 I bought a new pre-assembled hotend. It was just delivered and I put it in place. But it does not heat.
The previous was damaged when I tried to disassemble it after a filament clot. However, it still heated.
I did some checks and steps:
- The heatbed heats. The temperature sensors of heatbed shows reasonable values.
- So does the temp sensors of the hotend. It indicates room temperature.
- I checked all connections, all fine.
- I flashed latest firmware 3.4.1 and did the preheat again.
No change. The hotend stays cold. After a while the display indicates a PREHEAT ERROR.
What else can I try?
Any idea?
Veröffentlicht : 09/10/2018 8:28 pm
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
Re: Hot end does not heat
is the new hotend from Prusa? If so, please contact the support via live-chat at shop.prusa3d.com
Assembly manuals
/ Knowledge Base
Veröffentlicht : 10/10/2018 4:44 pm
gulprint
(@gulprint)
Yes, original. I did so, thanks.
Veröffentlicht : 10/10/2018 11:25 pm
gulprint
(@gulprint)
checked with the support and meanwhile received a replacement heat cartridge. Still I have the same issue: the hotend remains cold.
What else could I check to see where the problem is? How can I reliably check to see whether there is power for the hotend?
Is there any element on the logic board that I could check?
Thanks for advice.
Veröffentlicht : 19/10/2018 6:44 pm
Neal
 Neal
(@neal-3)
Fuse?
Neal
Veröffentlicht : 19/10/2018 6:48 pm
gulprint
(@gulprint)
Hi Neal,
good point. One of the two 5 fuses is gone.
I'll order and check again.
Thx,
Gerd
Veröffentlicht : 20/10/2018 12:22 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
The fuses are standard automotive type available anywhere auto parts are sold anywhere in the world pick up a few of each size they are cheap and useful to have on hand
Veröffentlicht : 20/10/2018 1:40 pm
gulprint
(@gulprint)
Oh, yes, I see now. I got a few from local hardware store 🙂 it heats ... thanks again!
Veröffentlicht : 20/10/2018 3:10 pm
