Horrible fail, time to upgrade?
KatJacRocketship
(@katjacrocketship)
I woke up to a hube blob of PLA+ enveloping the bottom part of my i3 MK3S extruder body. I'm expecting to be replacing some parts like the fan shroud, thermistor, and heater core. I'm still pretty new to 3d printing so I'm not sure if I should upgrade these things since and have to replace them. Suggestions for a noob?
Opublikowany : 29/11/2023 6:14 pm
Search for 'blob of doom' to see how others have dealt with them.
Before doing anything, look at pictures of a clean extruder and note the position of the rather delicate wires that are currently hidden, if you damage them you will have to buy replacement parts as broken wires can't be rejoined.  If these are OK your heater and thermistor will probably be reuseable.
You have probably damaged your fan shroud and will need a replacement.
To remove it:
Raise the nozzle temperature to the printing temperature for the filament in question and allow it to heat for several minutes.
If you are lucky you will be able to prise the blob open - more likely you will need to add heat from outside with a heat gun to aid the softening, sometimes it's worth using a soldering iron to carve chunks off the mass.
Use needle nosed pliers to prise this away; remove it in parts if it won't release the wires.
Once you have the worst removed you decide whether you need to disassemble the extruder to get at all the blob or perhaps you can clean up in situ.
After the cleanup there will be overcooked filament inside the nozzle so at least a purge and probably a cold-pull will be necessary.
Opublikowany : 30/11/2023 5:04 am
KatJacRocketship
(@katjacrocketship)
RE: Horrible fail, time to upgrade?
Thank you Diem. I got it off and the wires survived!!
Opublikowany : 30/11/2023 2:10 pm
