horizontal lines in print
Sherif
(@sherif)
Hello,
I was debugging an issue with my PTFE tube, there was some squeaky sound and I had to remount it again but still, it will be high a couple of mm, so I had to trim it a bit since it was already a bit damaged from the extruders gears, till I get a new one. The squeaks are gone, however now I notice that I have horizontal every maybe 2 cm, after I assembled the printer, I did a full calibration, and everything was perfect, what this could be? I can't think of anything, it is like there is a point between x and y that causes this line, how can I check that?
Thanks
Respondido : 09/12/2018 12:17 am
thrawn86
(@thrawn86)
Re: horizontal lines in print
going to need some pictures
Respondido : 09/12/2018 5:42 am
Sherif
(@sherif)
False alarm, it turned out to be the lines from the 1st layer calibration 😀 however I totally screwed my thermostat wires, so gonna get a new one:) thanks 🙂
Respondido : 09/12/2018 12:34 pm
