RE: help with sequential printing
there are Informations about Sequential printing in the knowledge Base (here)
Your print is probably higher than 20mm (which is defined under you checkbox for sequential printing (only in Expert Mode!).
This settings makes sure your printer wont crash into your part with the X-Axis steel rods.
Opublikowany : 19/08/2020 6:00 pm
