Help with Gcode
Rob
 Rob
(@rob-19)
Utenti
Help with Gcode
Hello,
I have reinstalled octopi in my raspberry pi connected to my 3D printer. And now I have the following issue: old files I sliced with PrusaSlicer are working fine. The printer starts, heats, does the bed calibration and starts printing, so, the hardware is fine. But now, when I slice a new design and upload it to the printer directly from PrusaSlicer, it seems like it skips the heat-up step and goes directly to bed calibration and when starts the extrusion, it won't pull the filament. Here is the Gcode:
M73 P0 R164
M73 Q0 S165
M201 X1000 Y1000 Z200 E5000 ; sets maximum accelerations, mm/sec^2
M203 X200 Y200 Z12 E120 ; sets maximum feedrates, mm / sec
M204 S1250 T1250 ; sets acceleration (S) and retract acceleration (R), mm/sec^2
M205 X8.00 Y8.00 Z0.40 E4.50 ; sets the jerk limits, mm/secM205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
; printing object Isofix (1).STL id:0 copy 0; stop printing object Isofix (1).STL id:0 copy 0
;TYPE:Custom
M862.3 P "MK3S" ; printer model check
M862.1 P0.4 ; nozzle diameter check
M115 U3.14.0 ; tell printer latest fw version
M83 ; extruder relative mode
M104 S245 ; set extruder temp
M140 S90 ; set bed temp
M190 S90 ; wait for bed temp
M109 S245 ; wait for extruder temp
G80 X63.2823 Y74.2602 W69.624 H51.4833 ; mesh bed levelling
G1 Z0.2 F720G1 Y-3 F1000 ; go outside print areaG92 E0G1 X60 E9 F1000 ; intro lineG1 X100 E12.5 F1000 ; intro line
G92 E0M221 S95
; Don't change E values below. Excessive value can damage the printer.M907 E430 ; set extruder motor currentG21 ; set units to millimetersG90 ; use absolute coordinatesM83 ; use relative distances for extrusion
M900 K0.08 ; Filament gcode LA 1.5M900 K45 ; Filament gcode LA 1.0
Please, help, it is driving me nuts...
Postato : 06/09/2024 6:59 pm
Rob
 Rob
(@rob-19)
Utenti
RE: Help with Gcode
update: It was not the Gcode. Apparently, the problem was when I uploaded the gcode via octopi. If I saved it in the SD card introduced in the laptop, the gcode works just fine, but via octoprint I guess the file gets corrupted or a plug-in mess with it.
Postato : 06/09/2024 10:46 pm
