Help with Color Print
Okay, so I have tried using Color Print and it works great as long as I'm only inserting one change. Anymore more than that though it fails to add them. It's been this way for quite awhile.
I usually just manually edit the gcode.
Is there another utility that does this? Or has anyone developed a script for this?
Would like an easier way to insert the M600 command for filament change than manually editing gcode.
What would be best is a visual tool where you can see the model and where the filament change is visually.
Thanks,
Justin
Opublikowany : 07/12/2018 9:28 pm
