Help! Calibration failed. Check axes and run again.
proX gaming
(@prox-gaming)
So I bought this printer (mk3s) 2nd hand a couple weeks ago I've done several projects with it no problem. Last night I had the filament clog during a print and after that the z was not calibrated anymore. I've tried doing the z and xyz calibration and all it does it go up then as soon as it gets back down to the bottom of the z it errors before even searching for the first point. I've tried cleaning the z rails and nothing changed.
This topic was modified 2 years temu by proX gaming
Opublikowany : 24/04/2024 6:39 am
proX gaming
(@prox-gaming)
RE: Help! Calibration failed. Check axes and run again.
I have also tested the prinda sensor and it is functional
Opublikowany : 24/04/2024 6:45 am
Robin
(@robin)
A video of the failing calibration would be helpful.
Opublikowany : 24/04/2024 9:39 am
proX gaming
(@prox-gaming)
Here's a link to the video of the failed xyz calibration https://youtube.com/shorts/xW1M85R7Zsk?si=lg41vmKM5w-9JCEN it does the same thing when I do just a z calibration.
Opublikowany : 24/04/2024 9:53 pm
proX gaming
(@prox-gaming)
Well I figured it out. I feel stupid. I had flipped my spool holder around because I felt that it fed better this way and when I flipped it, it got in the way of the z axis.
Opublikowany : 25/04/2024 5:58 am
Robin
(@robin)
No need to feel stupid, be happy you figured it out… happy printing!
Opublikowany : 25/04/2024 6:29 am
