Help! Big blob with err mintemp !
Namlu'u
(@namluu)
Hello world!
This morning is black morning for my printer MK3!
A big blob was installed on the nozzle. It's not the first time. In this case, I follow the process show in this video:
BUT now, with the blob, there are an error MINTEMP. So the printer can't preheat the nozzle!
How I can repair the printer??
Thanks!
Loïc
Opublikowany : 24/04/2018 12:32 pm
DevDoc
(@devdoc)
Re: Help! Big blob with err mintemp !
Most likely your thermistor is damaged. Look at the wires coming out of the cartridge in the side of the heater block. The thermistor is not terribly expensive and can be shipped from the US (assuming you are in the US) via one of the E-3d partners if shipping from Prusa is prohibitive on such a small order.
Opublikowany : 24/04/2018 10:07 pm
Namlu'u
(@namluu)
Thanks for your reply.
I removed the blob with a soldering iron. But the wires of hotend thermistor are broken. So I ordered a new thermistor. I wainting the shipping...
Next step in the next episode...
Opublikowany : 26/04/2018 12:50 am
Hi Loic,
did you order two thermistors?
one for now, and one for the future?
Joan
Opublikowany : 26/04/2018 1:05 am
Zipp
 Zipp
(@zipp)
Right out of the box, bought assembled, did the calibration and tried to print a frog, ended up with a blob, heated up and removed blob now with Minitemp err.
for %$#$^&(* where do i get another thermistor, not off to a good start prusa
Opublikowany : 01/12/2018 2:47 am
Mustrum Ridcully
(@mustrum-ridcully-2)
Since you bought an assembled printer your first stop is the Support chat system which runs 24-7-365 log on to any of the Prusa online store pages, select the chat popup in the lower right corner of the page.;Enter your order number so they identify you as a buyer of the assembled printer and you will get excellent service.
depending on where in the world you are you may want to buy a few of the thermistors for use after the warranty is over I get My spares here;
in the USA this is the best source for proper Prusa parts
https://www.printedsolid.com/collections/prusa?fbclid=IwAR3JJEWMkxDvFb_R_i8ZAwma56wyDWIxC2DvhpT80Jw9sfD1UyGc_Saynfc
Opublikowany : 01/12/2018 5:25 am
