Heating nozzle restarts printer
SeniorBurrito
(@seniorburrito)
I was trying to do the setup wizard, but when it got to heating the nozzle, it reset the printer. It happens both when I attempt to go thru the wizard and when I attempt to heat it manually. There is no way for me to adjust the temperature. Any thoughts?
Opublikowany : 14/05/2023 1:27 am
Hello
(@hello)
RE: Heating nozzle restarts printer
The wires on the hotend are probably shorting check the wires where they go bear just before they enter heat block if there not touching open the einsy case go to the hotend wires at the connection to board see if they are touching there
Opublikowany : 15/05/2023 4:28 am
