"Heating disabled by safety timer" error
K Carlo
(@k-carlo)
Hi there, so I left the printer going overnight and woke up to an error message reading "Heating disabled by safety timer", I haven't run into that error message before, wondering if anyone know what went wrong so I can avoid it happening again, thanks!
Postato : 29/05/2018 5:45 pm
Re: "Heating disabled by safety timer" error
Hi Karen,
that message normally occurs if you set the printer to Pre Heat, and forget to start a print.
I can't think what would cause it, if you left the printer, printing...
Postato : 30/05/2018 12:51 am
K Carlo
(@k-carlo)
The printer was definitely printing, and had gotten through about 3/4" of the print when it stopped. It made me remove and reload the filament, but then it resumed printing at that point. Curious what caused it though.
Postato : 30/05/2018 1:14 am
stephen.h14
(@stephen-h14)
Having to reload the filament might be a clue? I wonder if the safety timer kicked in after a filament sensor error?
Postato : 30/05/2018 1:24 am
