"Heating disabled by safety timer" error
Hi there, so I left the printer going overnight and woke up to an error message reading "Heating disabled by safety timer", I haven't run into that error message before, wondering if anyone know what went wrong so I can avoid it happening again, thanks!
Re: "Heating disabled by safety timer" error
Hi Karen,
that message normally occurs if you set the printer to Pre Heat, and forget to start a print.
I can't think what would cause it, if you left the printer, printing...
The printer was definitely printing, and had gotten through about 3/4" of the print when it stopped. It made me remove and reload the filament, but then it resumed printing at that point. Curious what caused it though.
Having to reload the filament might be a clue? I wonder if the safety timer kicked in after a filament sensor error?
