Heating Block of HotEnd moves
ChiSao
(@chisao)
after I changed my nozzle from 0.4 to 0.6 my heating block moves a little bit like if there is a not tighten screw.
It happens when I removed the old nozzle. I tried carefully to hold the heating block like described in the manual, but afterwards the block was loose. I could fix the new nozzle but I don't know how to refix/screw/tighten the heating block. Or did I break something?
Thanks for your help
Opublikowany : 13/03/2019 2:02 pm
Re: Heating Block of HotEnd moves
Did you follow the nozzle change procedure in the manual?
Nozzles must be changed while hot: 280c. And properly torqued against the heat break. If you didn't follow the manual, your nozzle is probably tightened against the heater block and not the heat break, and you'll have all sorts of problems.
Opublikowany : 13/03/2019 9:24 pm
