Heated Bed Thermistor Issues.
I got the MINTEMP BED error in the middle of a print after only a few months of light use. I performed the test by switching the thermistor cables and I got the message to switch as expected. I performed the resistance test and it is a constant zero. I removed the bed and examined the cable and there are no signs of wear at all. Does this mean the thermistor is bad? If so why would it fail in such a short time?
Publié : 24/12/2019 9:34 pm
