Heatbed temperature peaks
So, I've started to see some kind of temperature peaks on my MK3 heatbed. It didn't bothered me, until I've lost a print due to this error: (Error: Temperature heated bed switched off. MINTEMP triggered !).
It's a thermistor problem, or, maybe I can solve it myself adjusting something?
Opublikowany : 09/05/2018 7:41 pm
Re: Heatbed temperature peaks
You might have a broken/intermittent thermistor wire somewhere in the harness. Also check the connection at the einsy.
Opublikowany : 09/05/2018 8:55 pm
Check if the thermistor have escaped from the tape under the headbed.
Gert
Opublikowany : 09/05/2018 9:47 pm
Topic starter
answered:
Well, I finally fixed it by changing the thermistor. It wasn't as difficult as I expected.
Opublikowany : 11/05/2018 3:43 am
