heat block leaking. how to tighten?
Enceladus42
(@enceladus42)
I'm getting plastic oozing (although very small amounts) down the side of the heat block (where the nozzle screws into).
What is the best way to tighten this back up please?
Threadlocker any good to prevent it happening again?
Ta 🙂
Veröffentlicht : 01/08/2021 10:49 am
Mitglied
leaking
Photos might help.  My guess is your hotend is not assembled correctly.  The nozzle is not against the heatbreak.  Look at the image below.
Veröffentlicht : 01/08/2021 12:01 pm
Enceladus42
(@enceladus42)
yup!
that looks like the problem.
how do i fix it?
Veröffentlicht : 01/08/2021 4:43 pm
BogdanH
(@bogdanh)
Posted by: @enceladus42
how do i fix it?
As shown on the cwbullet's picture: First you need to screw in the heatbreak deeper into the heatblock, so you get (about 0.5mm) gap between heat block and nozzle (green line on picture). Keep in mind, filament is sealed only where heatbreak and nozzle touch each other (threads don't seal).
[Mini+] [MK3S+BEAR]
Veröffentlicht : 01/08/2021 6:10 pm
Ringarn67
(@ringarn67)
This is from the manufacturer of the hot-end
https://e3d-online.dozuki.com/Guide/Changing+Nozzles/45
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Veröffentlicht : 01/08/2021 6:51 pm
