Hear bed resistance and inconsistent heat
ChrisMacgyver
(@chrismacgyver)
Hi everyone,
i am wondering about that the heat bed is not evenly heated. Target is 48 degrees. Nearest is 45 and coldest is 38. The resistance of the board is 2,4 ohms if i subtract the 0,2 readings if i connect the test leads directly to each other. Means with 23,45volts gives me 9,7 amps. Is this a reasonable reading?
Kind regards
Chris
Publié : 25/06/2019 2:43 pm
