[Risolto] Having trouble updating to the latest firmware.
ioneng
(@ioneng)
I'm trying to update my mk3s with prusaslicer runinng on windows 10, but it keeps timing out on the com port connection:
avrdude-slic3r -v -p atmega2560 -c wiring -P COM4 -b 115200 -D -U flash:w:0:F:\Downloads\prusa3d_fw_MK3S_3_8_0_2684.hex:i
avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on May 20 2019 at 18:52:49
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
Using Port : COM4
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude-slic3r: stk500v2_recv(): timeout
avrdude-slic3r: stk500v2_getsync(): timeout communicating with programmer
avrdude-slic3r: Could not open port: COM4
avrdude-slic3r done. Thank you.
So I'm on firmware 3.7.2 at the moment. I updated it from 3.7.1 using prusaslicer the same way I'm doing now.
I can print with pronterface on the same com port. I can print with octopi. When I tried to update with the firmware updater plugin for octoprint , it also timed out.
I've only been using the printer for a couple of months so I'm still kinda new at it all. Does anyone have any idea what could be the cause of this?
Postato : 07/09/2019 12:53 pm
ioneng
(@ioneng)
RE: Having trouble updating to the latest firmware.
I got it working after following suggestions on this discussion:
https://stackoverflow.com/questions/19645441/avrdude-stk500v2-receivemessage-timeout
Basically I clicked on the flash button in Prusaslicer immidately after I pressed reset button on the printer. I have no idea why this works but if you have the same problem, give this a try.
After flashing and the printer reboots, Prusaslicer will complaine that it lost connection with COM port, but this is ok. Firmware has already been flashed.
Postato : 09/09/2019 5:59 am
5 persone hanno apprezzato
The_Meez
(@the_meez)
This tip just ended a morning of frustration for me. Thanks! Surprised this is still an issue after so many years.
My printer has been sitting for a few months, and I was worried it had died of loneliness or something. 😛
Postato : 04/04/2023 2:52 pm
Witz End Fabrications
(@witz-end-fabrications)
Utenti
Wow! Thank you so much! This fixed my issue when upgrading my MK3 to an MK3S+!
Postato : 22/08/2023 8:32 pm
Plastikschmiede
(@plastikschmiede)
That, Plus Switching my Port on the PC a few times got it working.
Before it shutted down after aprox. 44%.
Tank you!
Postato : 25/11/2023 12:07 pm
