Going Octo but wich hardware?
STAFFSMITH.EU
(@staffsmith-eu)
Im planig to install Octoprint in my setup.
Shut i buy a Pi Zero W or shut i got with my Pi b+?
Wich is the better Hardware for my mk3?
Postato : 22/01/2019 12:20 am
Nikolai
(@nikolai)
Re: Going Octo but wich hardware?
With PI zero you can hide it inside the main case, no additional cables.
With RPI 2b+/3 you can make time lapses and all the other more powerful stuff.
At the end it's up to you what's use cases.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Postato : 22/01/2019 12:41 am
STAFFSMITH.EU
(@staffsmith-eu)
The one i have is a Raspberry Pi 1 Modell B+
So there not a lot more i can do than with the Zero w ?
Postato : 22/01/2019 12:51 am
Nikolai
(@nikolai)
The only benefit you will get if you switch from 1B+ to zero W is the space and no cable.
If you compare the specs, zero W is just slightly faster which you could also achieve with fan+overclocking on 1B+. But at the end they can run both Octoprint without any issues.
Often linked posts:
Real Multi Material
Postato : 22/01/2019 12:55 am
STAFFSMITH.EU
(@staffsmith-eu)
hmm sounds good. 🙂
Thx for the advice.
one last question, do i need to solder the Pi Zero?
some guides say yes bud in some i cant fine nothing a bought it.
Postato : 22/01/2019 1:01 am
Nikolai
(@nikolai)
STAFFSMITH.EU
(@staffsmith-eu)
Thank you for your patient advice!
Happy making for you.
greetz Thorben
Postato : 22/01/2019 1:11 am
Nikolai
(@nikolai)
Anytime. Happy Printing! 🙂
Often linked posts:
Real Multi Material
Postato : 22/01/2019 1:12 am
richard.l
(@richard-l)
Utenti Moderator
No soldering required.
I believe this is wrong. You still need to solder the pin header to the RPi Zero. It will then just plug into the Einsy board.
Postato : 22/01/2019 4:01 pm
richard.l
(@richard-l)
Utenti Moderator
hmm sounds good. 🙂
Thx for the advice.
Steps 5-7 on this page explain what needs to be done..
https://manual.prusa3d.com/Guide/0.+Preparing+necessary+components/585?lang=en
Postato : 22/01/2019 4:19 pm
Nikolai
(@nikolai)
Thanks for clarification. It does make sense now why Thorben gets mixed information about this. If you buy Rpi Zero W already MK3 ready, you don't need to prepare it (no soldering). If you buy it with pins presoldered and you just need to cut out the unneeded ones, also no soldering. But if you get a stock one then you have to solder like in the guidelines.
Often linked posts:
Real Multi Material
Postato : 22/01/2019 6:36 pm
