Getting lots of lines on layers - New at this
Hello, I am kind of new at this. I wanted to try to print an among-us model. I ended up with lots of lines. I tried the right one at .20 first. I thought that it was too much, so I then moved to try the left one at .10 second. I am not really sure what I can do to fix the lines. Would anyone have any pointers?
Postato : 24/11/2022 3:15 am
Topic starter
answered:
RE: Getting lots of lines on layers - New at this
The material is 3d Fuel Pro PLA. I had the temperature to be 207C at nozzle, 50C at the bed. The feed speed was 20MM/s. I also did supports on the build plate only.
Postato : 24/11/2022 3:53 am
Test the belts for proper tension. Check the grub screws on the motor axles to make sure they're not slipping.
Postato : 24/11/2022 7:38 am
