Getting lots of lines on layers - New at this
George the Printer
(@george-the-printer)
Hello, I am kind of new at this.  I wanted to try to print an among-us model.  I ended up with lots of lines.  I tried the right one at .20 first.  I thought that it was too much, so I then moved to try the left one at .10 second.  I am not really sure what I can do to fix the lines.  Would anyone have any pointers?
Postato : 24/11/2022 3:15 am
George the Printer
RE: Getting lots of lines on layers - New at this
The material is 3d Fuel Pro PLA.  I had the temperature to be 207C at nozzle, 50C at the bed.  The feed speed was 20MM/s. I also did supports on the build plate only.
Postato : 24/11/2022 3:53 am
Test the belts for proper tension. Check the grub screws on the motor axles to make sure they're not slipping.
Postato : 24/11/2022 7:38 am
