getting 5v from Einsy Board?
RobertB67
(@robertb67)
Looking to get 5v from MK3 Einsy Board besides the P3 Connector as the MMU 2.0 will be using that connector, maybe somewhere from the Pi connector?
I will be running a 40mm fan from it so it should have power all the time if the printer is on, if printer is off no power to the 5v.
Thank You,
Robert
Publié : 07/11/2018 2:44 am
overflow
(@overflow)
Re: getting 5v from Einsy Board?
I used a stepdown power module like this one : https://goo.gl/HcUF71 picking up 24 volts from the power suppy. If you search it on aliexpress are cheaper.
Publié : 07/11/2018 4:49 pm
RobertB67
(@robertb67)
Does the stepdown power module get hot or warm ?
Publié : 07/11/2018 7:48 pm
Corto
(@corto)
You can use the RPi port. This is what I will do.
Publié : 11/11/2018 4:59 pm
toaf
 toaf
(@toaf)
pin2+ pin 20- should not be used by a pi 😀
Publié : 12/11/2018 12:49 am
RobertB67
(@robertb67)
Do you have the pin layout for the pi header?
Publié : 12/11/2018 10:55 pm
toaf
 toaf
(@toaf)
this should be correct guess it depends on the flavor of pi
Publié : 12/11/2018 11:02 pm
RobertB67
(@robertb67)
Cool, I can work with that 😀
Thanks!
Publié : 13/11/2018 7:08 am
toaf
 toaf
(@toaf)
im just glad it wouldn't mess with a pi much. lucky I added 24 volt fans and lights.
might wana messure it once to make sure
Publié : 13/11/2018 7:35 am
toaf
 toaf
(@toaf)
dude, im a ID10T. that was wiring for the pi. o well hope you just used that. I was looking into safe wires that wouldn't mess with a pi. 100% my bad. I don't think you would find a pin 20..
Publié : 14/11/2018 10:20 am
