GCode viewer will not open.
Eddie9195
(@eddie9195)
Hello,
I am having an issue with the GCode Viewer not opening. It was working fine last night. I am getting an error message that the .ini file may be corrupt and to manually delete the file to recover from the error. I haven't been able to find the GCode program to try and delete it.
I have reinstalled the Prusa Slicer software and that did not help. Has anyone else had this issue? Were you able to fix it?
Thank you.
Respondido : 06/04/2021 3:28 pm
ArjunS
(@arjuns)
RE: GCode viewer will not open.
I'm having the same issue. Did you ever figure out a solution?
Respondido : 17/12/2021 9:17 pm
Vexorg
(@vexorg-2)
Did this ever get resolved? I have just tryed to use the viewer and it will not open in 2.4.0
Respondido : 25/01/2022 1:05 am
jwvaughn
(@jwvaughn-2)
Just tried it with 2.4.0 and it worked fine...
jwv
Respondido : 25/01/2022 6:21 am
