GCODE command for Stealth Mode on MK3?
Andrew Whittle
(@andrew-whittle)
Is there a gcode command for Stealth mode? I think the below was for MK2 and not sure if it would work for MK3
M907 X540 Z830 E500 for high power mode
M907 X270 Z830 E450 for silent mode
Opublikowany : 10/05/2018 5:28 am
thrawn86
(@thrawn86)
Re: GCODE command for Stealth Mode on MK3?
I have also wondered if there was a reference to prusa-specific codes like that, allowing you full functionality without futzing with the display. Maybe there is, and my google-fu is failing me.
Opublikowany : 11/05/2018 7:47 am
Dreide
(@dreide)
Best option seems to be looking into the source code ( https://github.com/prusa3d/Prusa-Firmware/blob/dd8922653702b853df8cf588d134d58270437f06/Firmware/Marlin_main.cpp#L6485 ).
Normal mode: M914
Silent mode: M915
Opublikowany : 11/05/2018 6:39 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Or even the wiki: https://github.com/prusa3d/Prusa-Firmware/wiki/Supported-G-codes
But it would appear that is not up to date 🙁
Peter
Opublikowany : 11/05/2018 9:54 pm
julian.s10
(@julian-s10)
RE: GCODE command for Stealth Mode on MK3?
I am looking for that command too and M915 ; placed in start G-code seems to be not working. Does anyone know if there's working one?
Opublikowany : 21/06/2019 8:29 pm
julian.s10
(@julian-s10)
In the current firmware code: https://github.com/prusa3d/Prusa-Firmware/blob/MK3/Firmware/Marlin_main.cpp in line 3292 the M915 is not listed so I assume it's not supported yet.
Opublikowany : 21/06/2019 8:37 pm
ssmith
(@ssmith)
The firmware has gcodes "M9140" to clear and "M9150" to set stealth mode. The terminal response shows them accepted, but I haven't done any testing to see whether they're effective.
Send: M9150
Recv: Stealth mode enabled
Recv: ok
Send: M9140
Recv: Stealth mode disabled
Recv: ok
Opublikowany : 22/04/2025 5:36 pm
ssmith
(@ssmith)
I see that on an XL the M9140/M9150 gcodes effect the 'Stewalth Mode' setting in the LCD display...
Opublikowany : 22/04/2025 6:10 pm
