Garbage on Display
craig.s14
(@craig-s14)
Garbage on Display
I have been getting these jumbled displays for a while, but this morning, I woke up to this and now cant get it to reset or anything. Any suggestions?
Respondido : 12/04/2019 4:26 pm
vintagepc
(@vintagepc)
Miembro
Re: Garbage on Display
Have you made sure your connectors for the display are firmly seated and the cables are not damaged? I'd start there.
The displays are quite sensitive to static discharge, if you've zapped it by accident it may need to be replaced.
If you still have a problem then your next best bet is to hit up prusa online chat; they will get you sorted with a replacement if you are eligible.
Respondido : 12/04/2019 4:31 pm
