Gaps in sliced model
Scouter456
(@scouter456)
Hello,
After slicing a model in Cura I seem to have gotten gaps in the program.
Is this just visual or something else. Because at a print I did earlier the places these spots are in seem rather bumpy.
Opublikowany : 12/11/2019 11:26 pm
RE: Gaps in sliced model
Is that the z-seam? Cura does coasting where extrusion stops before the end of lines.
Opublikowany : 13/11/2019 2:19 am
K7ZPJ
(@k7zpj)
Your picture looks like you have coasting enabled in Cura.
The purpose of Coasting is to reduce stringing when the z-axis is raised.  Coasting replaces the last part of the extrusion path with a travel path.   The extruder is then expected to have enough internal pressure to ooze enough plastic to print the last part of the path. When there isn't enough pressure / ooze, you get holes in the print.   Try slicing with "Coasting Enabled" unchecked and see if they holes go away.
Opublikowany : 13/11/2019 2:40 am
Scouter456
(@scouter456)
Yes, had coasting enabled. Turned it off and the problem is gone. Thank you
Opublikowany : 13/11/2019 4:43 pm
