Gaps in printouts with Prusaslicer 2.4.1 - can also be seen in Slicer
rbx;-)
(@rbx)
Hello community,
since two days I have astrange phenomenon of missing layers in the printout again and again.
At first I suspected that it was due to the filament (snagged, old and brittle) or the nozzle (underextrusion). But I was able to eliminate all of these factors by experimenting.
When I took a closer look at the slices in PrusaSlicer, I could also see these missing parts (see picture).
The same *.stl on another computer still with PrusaSlicer 2.4.0 version, does not show these defects.
Is it because of the version? Is there a setting that has been adjusted? A problem of the setting?
Publié : 07/04/2022 11:23 am
RE: Gaps in printouts with Prusaslicer 2.4.1 - can also be seen in Slicer
that looks like errors in the STL, causing slicing errors., or very thin sections narrower than the extrusion width, causing slicer to ignore those sections,
could you please attach your project file. or stl so we can help more
or, when in prusa slicer Editor View,
if you are using windows, you should be able to right click on the selected model, and select "Fix through the NetFabb"
which may be able to correct any errors for you...
Publié : 07/04/2022 2:02 pm
