G80 repeated parameter
Douglas Urbano
(@douglas-urbano)
Hi All,
I was developing a software to automatically tune the bed leveling using optuna, but I noticed something about the G80 command.
According to the knowledge base:
G80 - Mesh-based Z probe G80: Mesh-based Z probe
Default 3x3 grid can be changed on MK2.5/s and MK3/s to 7x7 grid.
Usage
G80 [ N | R | V | L | R | F | B ]
Parameters
  • N - A number of mesh points on the x-axis. The default is 3. Valid values are 3 and 7.
  • R - Probe retries. Default 3 max. 10
  • V - Verbosity level 1=low, 10=mid, 20=high. It only can be used if the firmware has been compiled with SUPPORT_VERBOSITY active.
Using the following parameters enables additional "manual" bed leveling correction. Valid values are -100 microns to 100 microns.
Additional Parameters
  • L - Left Bed Level correct value in um.
  • R - Right Bed Level correct value in um.
  • F - Front Bed Level correct value in um.
  • B - Back Bed Level correct value in um.
The problem is that it uses the same parameter R for both probe and Right, is there a way to differentiate them?
Este debate ha sido modificado el hace 6 years 3 veces por Douglas Urbano
Respondido : 14/08/2020 10:36 am
