G-code start/stop code procedure for heating procedure
Bobertsawesome
(@bobertsawesome)
Is it possible for a startup code for beginning the heat procedure to a lower temperature, like 170, and then running the bed leveling, which after completion puts the nozzle down to bed to heat until the full temp? I saw it done in this gcode https://shop.prusa3d.com/forum/assembly-and-first-prints-troubleshooting-f62/life-adjust-z-my-way-t2981.html . But I think the gcode might have been manually edited after it was exported. It appeared to be such when I opened the code in raw form.
PJR (Peter) was referenced as the guy behind the preheat procedure, but I looked to see if he ever released anything, which I haven't found. If it's not possible to do in settings of S3D for start/end gcode, does anyone have anything similar that works like such?
Thanks for any and all support! 😀
Publié : 16/07/2018 7:29 am
Martin Wolfe
(@martin-wolfe)
Re: G-code start/stop code procedure for heating procedure
See my answer in Extruding too much filament before printing
Regards,
Martin
Martin Wolfe
Publié : 16/07/2018 7:43 am
Bobertsawesome
(@bobertsawesome)
Regards,
Martin
Thanks so much! This is perfect :).
Publié : 16/07/2018 10:49 pm
