g-code sliced for a different printer type message
nustherapy
(@nustherapy)
I have a couple of different printers, and although Prusa Slicer makes it really easy to remember and visually see what you are slicing for with the proper beds represented, I have 2 MK3S, one has a MMU the other does not. Although it's poor form on my side I will often be working on a project and printing on both printers, and forget to change the printer I'm going to print the next part on.  When the warning "g-code sliced for a different printer type continue?" message comes up am I missing something or is the only option to continue? Of course I can reset the machine but this is a bit annoying especially with the MMU as it will reset that unit as well. Not a big issue but also I'm really surprised there isn't a simple yes/no option there... or is there something I'm missing?
Opublikowany : 21/08/2022 2:12 am
RE: g-code sliced for a different printer type message
In your printer's menu, under Hardware Setup, you can set the warning level to strict, which will abandon the print if an incompatibility is detected.
Opublikowany : 21/08/2022 11:34 am
