G-Code Flavor
TerryK
(@terryk)
G-Code Flavor
Had a print fail using Prusa Slicr 2.3.0
Printed about 2mm in Z and then moved over to X,Y, Zero and crashed there. It gave me the choice to continue the print, which I did. But then it quit extruding filament.
I removed the filament, then re-inserted it and ran a part I've run before and had no problem. Took a look at Printer Settings and saw a selection for G-Code flavor. It was set to Marlin, but it said the default was RepRap/Sprinter. Should I change it to that?
Can these be related? What G-Code flavor should I be choosing?
Posted : 09/08/2021 5:59 am
Jeff K
(@jeff-k)
RE: G-Code Flavor
Did you ever get a response to this?
Posted : 23/05/2022 11:39 pm
RE: G-Code Flavor
My Slicer runs 'Marlin Legacy' for the G code flavour which is Prusa's default value  (Prusa slicer is based on the original 'Slic3r' heritage, and the comments windows default values do not appear to have been updated from the Slic3r era... )
I suspect the original issue was too many XY Collisions causing the printer to wait for user input, maybe the extruder had cooled below 170C before the user continued with the print, and low temperature extrusion settings kicked in preventing  further extrusion.
Posted : 24/05/2022 1:18 am
bryn51
(@bryn51)
RE: G-Code Flavor
Please be more accurate when you talk about gcode flavour.  There is no selection for "Marlin".  There is selection for "Marlin (Legacy)" and another "Marlin 2".
Posted by: @terryk
Posted : 16/10/2024 2:01 am
RE: G-Code Flavor
Bryn51, back when Terry posted originally there was only Marlin. There was no marlin 2. It has since been split to marlin legacy and marlin 2. So they were being quite accurate.
Posted : 16/10/2024 5:10 am
